mng1
DSD question on Blocking at 4 blocks vs 3 blocks
Designed a DSD experiment with 5 factors in JMP15.  Can only run 4 conditions at a time.  So added 4 blocks with center runs to estimate quadratic effects.  Expected a design with 4 conditions per block and a total of 16 conditions.  Instead, block 1 & 2 have 5 conditions, and block 3 & 4 have three conditions.  Tried to repeat or play around the setting still cannot get 4 conditions per block.  Not feeling comfortable in manually change the block #, which will change the power of the model as well as the correlation map.
Then, I tried using 3 blocks and the design gave 15 conditions == 5 conditions per block. The design looks good to move forward with but I can only run 4 conditions at a time.  Is selecting a 4 blocks setting become an issue due to the algorithm of the program?  Or I missed something in setting up this design.  Greatly appreciate for any suggestion or a round about way to get a DSD design 5 factors, total 16 conditions-- in 4 conditions per block.
Thanks,
Maria
Re: DSD question on Blocking at 4 blocks vs 3 blocks
I suggest you abandon the definitive screening design in this situation. The generator is somewhat inflexible and not appropriate for every screening case.
You can achieve what you want with the flexible custom design. You can add a Blocking factor defined as 4 runs per block. You can add all the interactions and all the quadratic terms. That model is the same as implied by the DSD. Select these higher order terms and change their Estimability to If Possible. Click the red triangle at the top and select Optimality Criterion > Make Alias Optimal Design. The DSD is an alias optimal design. I would use the same number of runs as created by the default DSD. That is 21 runs for your 5 factors with blocking.
Here is a script that will launch the Custom Design platform and set it up as I described so that you can try it for yourself.
DOE(
	Custom Design,
	{Add Response( Maximize, "Y", ., ., . ),
	Add Factor( Continuous, -1, 1, "X1", 0 ),
	Add Factor( Continuous, -1, 1, "X2", 0 ),
	Add Factor( Continuous, -1, 1, "X3", 0 ),
	Add Factor( Continuous, -1, 1, "X4", 0 ),
	Add Factor( Continuous, -1, 1, "X5", 0 ), Add Factor( Blocking, 4, "Block" ),
	Set Random Seed( 968796745 ), Number of Starts( 13195 ), Add Term( {1, 0} ),
	Add Term( {1, 1} ), Add Term( {2, 1} ), Add Term( {3, 1} ), Add Term( {4, 1} ),
	Add Term( {5, 1} ), Add Term( {6, 1} ), Add Potential Term( {1, 1}, {2, 1} ),
	Add Potential Term( {1, 1}, {3, 1} ), Add Potential Term( {1, 1}, {4, 1} ),
	Add Potential Term( {1, 1}, {5, 1} ), Add Potential Term( {2, 1}, {3, 1} ),
	Add Potential Term( {2, 1}, {4, 1} ), Add Potential Term( {2, 1}, {5, 1} ),
	Add Potential Term( {3, 1}, {4, 1} ), Add Potential Term( {3, 1}, {5, 1} ),
	Add Potential Term( {4, 1}, {5, 1} ), Add Potential Term( {1, 2} ),
	Add Potential Term( {2, 2} ), Add Potential Term( {3, 2} ),
	Add Potential Term( {4, 2} ), Add Potential Term( {5, 2} ),
	Set Sample Size( 21 ), Optimality Criterion( Make Alias Optimal Design ),
	Simulate Responses( 0 ), Save X Matrix( 0 )}
mng1
Thanks Mark! Might look into another option then.  Thanks for the scripts.
