maxikom
Color Box-plots
I have read the other conclusions for coloring box-plots but there is no such functin in my graph builder :D
I want the plots in the picture to have diffrend colors, what can i do? I can just change the color of the points and the color of the background. I cant change the color of the plots.
hogi
Level XIII
Re: Color Box-plots
what happens when you drag the column onto "Color"?
(view in My Videos)
7 REPLIES 7
hogi
Level XIII
Re: Color Box-plots
(view in My Videos)
Re: Color Box-plots
Here is a similar graph to what you are showing in JMP 18
I changed the points to the color black so they are visible
The same similar results are available back through JMP 15.  However in JMP 14 a solid box plot does not honor the Color column
What version/release of JMP are you using?
maxikom
Re: Color Box-plots
i am using version 17.2
The method hogi uses works.
But I like it your way that every bosplot has got a different color. And that is what doesnt really work
Re: Color Box-plots
Here is the example that I have been using run in JMP 17.2.  Doesn't it give you what you want?
maxikom
Re: Color Box-plots
It does, now it worked. Thanks
dlehman1
Re: Color Box-plots
I would comment that txnelson's solution is a good example because the same series of categories repeats for the 2 genders.  However, if there was only the one set of categories (without the gender variable), then I think coloring the box plots is a bad idea.  It looks visually appealing but distracts from the actual data - in my opinion, a poor use of color.  With the multiple sets of categories, as in the example you posted, then I think the coloring is useful.
hogi
Level XIII
Re: Color Box-plots
Good point.
For some cases it even makes sense to use the color for the "outer" categories:
