robot
Do Not Open CSV File after 'Save As'
Within JMP, after I save a JMP table as type CSV using 'Save As', the CSV file will automatically open in MS Excel (my default CSV program).  Is there a way to stop this behavior?  I would simply like to save the CSV file, and not open it afterwards.  I searched the JMP preferences menu, and found no obvious options.
JMP 14.3.0
Windows 10 Pro, Version 1909
Microsoft 365 Apps for enterprise
Thanks!
Craige_Hales
Re: Do Not Open CSV File after 'Save As'
Checkbox on save as dialog only appears for some extensionsCheckbox on save as dialog only appears for some extensions
Craige
7 REPLIES 7
cwillden
Hi @robot ,
I don't know about anything in preferences, but the using dt << Save() in a JSL script with a .csv file extension does not open the saved filed.  I'm not sure if that can be suppressed for point-and-click saves.
-- Cameron Willden
statman
Just curious if this is a JMP "issue" or is it that your Excel program automatically opens it?  Perhaps look at preferences in the Microsoft product?
Craige_Hales
Craige
robot
@Craige_Hales  Brilliant!  Thank you!
Monomorphist
In JMP18, the box "Open the file..." seems to be ticked as default. As JMP user for more than 10 years, it annoys me to death that suddenly, I have to untick this box now every time I save a file as. Is there a way to change this default in the preferences? I couldn't find it
Craige_Hales
Pretty sure the setting used to be sticky, saved in the registry perhaps. Not where I can test it right now. Open a support ticket if no one comes up with an answer.
Craige
lala
Level IX
  • I only see this change. But it's not the answer.
