EndersGame
Clear cell colors
How do I script to clear all cell colors (not marker or row colors)? I know I can highlight all rows manually and right click and "clear color", but how I do this using script? Thanks in advance!
Re: Clear cell colors
JMP is able to script that for you
// Clear color for selected cells
Data Table("Untitled") << Select All Rows;
For Each({col}, {:Column 1, :Column 2}, col << Color Cells(""));
so with slight modification
For Each({colname}, Current Data Table() << Get Column Names("String"),
	Column(Current Data Table(), colname) << Color Cells("");
Select the column(s) you want to Clear the Cell Colors from, and then go to
     Cols=>Clear Cell Colors
