Color Box-plots
maxikom
I have read the other conclusions for coloring box-plots but there is no such functin in my graph builder
I want the plots in the picture to have diffrend colors, what can i do? I can just change the color of the points and the color of the background. I cant change the color of the plots.
Level XII
Re: Color Box-plots
what happens when you drag the column onto "Color"?
BoxPlot_Color.mp4
Video Player is loading.
Current Time 0:00
Duration 0:04
Loaded: 0.00%
Stream Type LIVE
Remaining Time 0:04
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Level XII
    Re: Color Box-plots
    BoxPlot_Color.mp4
    Current Time 0:00
    Duration 0:04
    Loaded: 0.00%
    Stream Type LIVE
    Remaining Time 0:04
    1x
      • Chapters
      (view in My Videos)
      Re: Color Box-plots
      Here is a similar graph to what you are showing in JMP 18
      I changed the points to the color black so they are visible
      The same similar results are available back through JMP 15.  However in JMP 14 a solid box plot does not honor the Color column
      What version/release of JMP are you using?
      maxikom
      Re: Color Box-plots
      i am using version 17.2
      The method hogi uses works.
      But I like it your way that every bosplot has got a different color. And that is what doesnt really work
      Re: Color Box-plots
      Here is the example that I have been using run in JMP 17.2.  Doesn't it give you what you want?
      maxikom
      Re: Color Box-plots
      It does, now it worked. Thanks
      dlehman1
      Re: Color Box-plots
      I would comment that txnelson's solution is a good example because the same series of categories repeats for the 2 genders.  However, if there was only the one set of categories (without the gender variable), then I think coloring the box plots is a bad idea.  It looks visually appealing but distracts from the actual data - in my opinion, a poor use of color.  With the multiple sets of categories, as in the example you posted, then I think the coloring is useful.
      Level XII
      Re: Color Box-plots
      Good point.
      For some cases it even makes sense to use the color for the "outer" categories:
