Coding Scheme JMP uses for Categorical predictors
Hi! Is there a way to know the default coding scheme that JMP uses for categorical predictors? I know that JMP uses -1 and 1 for a two-level factor, but I want to know how it sets for factors with multiple levels. Thanks!
Re: Coding Scheme JMP uses for Categorical predictors
See the documentation.
SamGardner
A way to see the actual coding for design is to fit a simple main effects model to the data (use simulated/random data for a response if you don't have it), and then in Fit Least Squares, select from the red triangle > Save Columns > Save Coding Table.  I have attached a table, that has an original design with a 2 level, 3 level, and 4 level categorical factor, along with the columns from the coding table joined into the design table.
