Artemio
Clean up a csv File
I have large quatity of csv files that need to be clean up.  All of these files have same format which make the task a bit easy.  My initial csv file has the following format:
Item Recipe:       (001)  48pt
Stage Recipe:       48pt
Batch ID:             Prod1
Item ID:           42
Date/Time:          5/1/2017 4:28:56 PM
PointMeasurementGainGFitXY
112.399.70.9911
212.299.90.9822
312.199.80.9833
The first 6 rows need to be clean up.  I'm thinking of getting the first 6 rows into a new table and transpose them.  After the traspose, join the table with the other section.  My ideal JMP table is the following:
Item Recipe:Stage Recipe: Batch ID:            Item ID:        Date/Time: PointMeasurementGainGFitXY
(001)  48pt48pt  Prod1  425/1/2017 4:28:56 PM112.399.70.9911
(001)  48pt48pt  Prod1  425/1/2017 4:28:56 PM212.299.90.9822
(001)  48pt48pt  Prod1  425/1/2017 4:28:56 PM312.199.80.9833
I'm trying a jsl script but it is behond my capability at the moment. Can someone give me an idea how to get this accomplish?
Thank you
Re: Clean up a csv File
Nice description of the problem, and I think your plan will work. You can use the text import preview wizard to do part of the work. By limiting the number of lines to 5, you can get the header, and by choosing fixed width fields you can get two columns (or maybe spaces, plural, would work even better for the delimiter). (If my cut-and-paste of your data messed up tabs and spaces you might need to tweak the column delimiters a bit). The source script is in the table and you can grab a copy of it for your bigger script:
Open(
    "C:\Users\v1\Desktop\x.txt",
    columns(
        Column( "c000001", Character, "Nominal" ),
        Column( "c000002", Character, "Nominal" ),
        Omitted Column( . )
    Import Settings(
        Fixed Column Widths( 13, 28, 98 ),
        Strip Quotes( 0 ),
        Use Apostrophe as Quotation Mark( 0 ),
        Use Regional Settings( 0 ),
        Scan Whole File( 1 ),
        Treat empty columns as numeric( 0 ),
        CompressNumericColumns( 0 ),
        CompressCharacterColumns( 0 ),
        CompressAllowListCheck( 0 ),
        Labels( 0 ),
        Column Names Start( 1 ),
        Data Starts( 1 ),
        Lines To Read( 5 ),
        Year Rule( "20xx" )
First five linesFirst five lines
Next, import again, skipping the 5 lines, and grab that script too:
Open(
    columns(
        Column( "Point", Numeric, "Continuous", Format( "Best", 12 ) ),
        Column( "Measurement", Numeric, "Continuous", Format( "Best", 12 ) ),
        Column( "Gain", Numeric, "Continuous", Format( "Best", 12 ) ),
        Column( "GFit", Numeric, "Continuous", Format( "Best", 12 ) ),
        Column( "X", Numeric, "Continuous", Format( "Best", 12 ) ),
        Column( "Y", Numeric, "Continuous", Format( "Best", 12 ) )
    Import Settings(
        End Of Line( CRLF, CR, LF ),
        End Of Field( Tab, CSV( 0 ) ),
        Strip Quotes( 1 ),
        Labels( 1 ),
        Column Names Start( 7 ),
        Data Starts( 8 ),
        Lines To Read( "All" ),
        Year Rule( "20xx" )
Data at bottom of fileData at bottom of file
All of the JSL above was written by the text import preview wizard and stored in the source script attached to the table.
The Subset section has part of the answerThe Subset section has part of the answer
Open(
    columns(
        Omitted Column( . )
    Import Settings(
        Strip Quotes( 0 ),
        Labels( 0 ),
        Data Starts( 1 ),
        Lines To Read( 5 ),
        Year Rule( "20xx" )
Open(
    columns(
    Import Settings(
        Strip Quotes( 1 ),
        Labels( 1 ),
        Data Starts( 8 ),
        Year Rule( "20xx" )
Artemio
Hi Craige,
It works as advertised.
Thank you so much
