saneal
Check if wafer from an input string is contained within a data table
I have an input string from below:
For( i = 1, i <= N Rows( dtWaferIDList ), i++,
	tempi = Column( dtWaferIDList, 1 )[i];
	InputString = If( i == 1, "'", "" ) || InputString || tempi || If( i < N Rows( dtWaferIDList ), "','", "'" );
And a table1 that I pull from a database. I would like to check to see if (in the Wafer column of table 1) all the wafers from the input string are contained in that column.
- if all wafers have data: display message = "data for all wafers available".
- if not: display message = "no data available".
Thank you!
Re: Check if wafer from an input string is contained within a data table
Use debug Show()s and small data set to test where you go wrong (open log window from View / Log).
Maybe this will help you forward:
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
dt1 << Select Rows([1,2,3]);
dt2 = dt1 << Subset(selected rows);
dt1 << clear select;
dt1_uniq = Associative Array(dt1:name);
dt2_uniq = Associative Array(dt2:name);
dt1_copy = dt1_uniq;
dt2_copy = dt2_uniq;
dt1_copy << Remove(dt2_copy);
Show(concat items(dt1_uniq << get keys, ", "));
Show(concat items(dt2_uniq << get keys, ", "));
Show(concat items(dt1_copy << get keys, ", "));
Show(N Items(dt1_uniq), N Items(dt2_uniq), N Items(dt1_copy));
9 REPLIES 9
You could most likely use Associative Array for this comparison Applications for Associative Arrays . Check out the part  Compare Columns in Two Different Data Tables
@jthi has pointed you in the right direction.  Your proposed approach is using a very long literal string.  I suggest that you either use associative arrays, or a JMP list.
Below is a simple script that opens a data table that contains wafers.  It then creates a data table that has a random set of wafers.  Finally it checks to see if the random set contains all wafers from the first data table.
names default to here(1);
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
unique wafers = associative array(dt:Wafer);
// Create a random wafer table and see if it contains all wafers
dtRand = new table("Random",
	add rows(60),
	new column("Rand Wafer", set each value(random integer(1,24)));
random wafers = associative array(dtRand:Rand wafer);
Random wafers << Intersect( unique wafers );
if(n items(Random wafers) == n items( unique wafers),
   msg = "data for all wafers available",
   msg = "no data available"
new window("Message", <<modal,
	text box(msg)
saneal
Hello Nelson,
I appreciate the help! I am a bit new to JMP still and haven't used Associative Arrays at all yet. I have read up on it on the scripting guide and index; but am still having some confusion. Here is where I am at in my code: (directly after opening the table WaferRgDt from a database)
unique wafers = Associative Array( WaferRgDt:Wafer );
given wafers = Associative Array( dtWaferIDList:WaferList );
intersection = unique wafers; intersection << Intersect( given wafers); //intersection between arrays
//uncommmon2 represents wafers that have no data associated with it.
uncommon2 = given wafers; uncommon2 <<remove(intersection); show(uncommon2 << Get Keys);
if(n items( given wafers ) == n items( unique wafers ),
   msg = "Data for all wafers is available.",
   //else
   msg = Write("\!N#Data is unavailable for the following wafers:", uncommon2 << Get Keys)
	text box(msg)
When I run this I get an empty messagebox with a period... so something seems wrong still. Wondering if its a logic issue or syntax. I have had some trouble finding how to write keys in a messagebox if its even possible to do. Hope that was clear enough. Thanks again!
saneal
Also used this discussion post to aid in writing the code aboveRe: Quick way to compare two lists (uncommon elements)?
To convert a list of strings into a string you can use Concat Items()
aa = Associative Array({"bun",
	"shoe",
	"tree",
	"door"}
uniqKeys = aa << get keys;
Show(uniqKeys);
Show(Concat Items(uniqKeys, ", "));
saneal
@jthi
I don't see how that solves my particular issue. When I run your script, nothing happens. I need the keys from the associative array to be visible to the user and displayed in a msg box.
//uncommon represents wafers that have no data associated with it.
uncommon = given wafers; uncommon2 <<remove(intersection); show(uncommon << Get Keys);
   //else
   msg = Show(Concat Items("\!N#Data is unavailable for the following wafers:", uncommon << Get Keys))
	text box(msg)
Your msg value is being specified incorrectly.  The below will work
msg = "\!N#Data is unavailable for the following wafers:" || Char( uncommon2 << Get Keys );
saneal
Thank you both! Looks to be working now. I appreciate it!
