Check if table exist on sql db
geoff1
I am running some jmpquery on different SQL DB. Because some DB do not have the same tables,  I getting the error:
Tables (public.table1(t1)) referenced in the SQL Query were not found in the database{1} in access or evaluation of 'Table' , Table( "table1", Schema( "public" ), Alias( "t1" ) ) /*###*/
How could I check if a table exists on a SQL DB before running a query ?
Thanks
Geof
geoff1
Re: Check if table exist on sql db
I found using the custom SQL below, it returns 0 or 1 if it exists.
obj = New SQL Query(
	Connection( "ODBC:DSN=xxxx" ),
	Custom SQL(
		"SELECT EXISTS (
SELECT FROM information_schema.tables
WHERE table_schema = 'public'
AND table_name = 'table1'
obj << run;
geoff1
it returns a table, how to get an argument? boolean ?
Georg
argument = N Rows(dt);
returns the number of rows of the table. If there is no row, the table was not there
Georg
pmroz
If this is SQL Server something like this (untested) should work:
schema_name = "PUBLIC";
table_name  = "TABLE1";
sql = evalinsert(
"SELECT COUNT(*) N
  WHERE table_schema = '^schema_name^'
    AND table_name = '^table_name^'");
dbc = create database connection("ODBC:DSN=xxxx");
dt = execute sql(dbc, sql, invisible);
close database connection(dbc);
ntables = dt:N[1];
if (ntables,
	print("Table " || table_name || " exists");
	print("Table " || table_name || " does not exist");
);close(dt, nosave);
