bbass
Charts are only partially showing up as interactive HTML
I have a set of charts that I want to save as an interactive HTML, but when the charts show up as a web page part of one of the charts is blacked out.  Could this be due to the chart displaying too much data?  I've tried with Chrome, Firefox, and Microsoft edge and they're all having the same problem.
Charts Displayed in JMP:
Charts displayed as Interactive HTML:
Re: Charts are only partially showing up as interactive HTML
Hi Brendon,
The blacked out area is a reference range on the X axis with an opacity of 0. Opacity0RefRange.PNGOpacity0RefRange.PNG
JMP treats this as completely transparent, but due to a bug in our Interactive HTML export, an opacity setting of exactly 0 is ignored causing the reference range to draw completely opaque.
I see a couple of options for anyone running into this issue until the bug is fixed.
1. Remove the reference area.
2. Use an opacity value of 0.0001.
In the script of the .jrp file you provided, the last parameter of the Add Ref Line function is the opacity set to 0.0001.
New Window( "Data Filter for Data Table",
	V List Box(
		Bivariate(
			Y( :WO % Complete ),
			X( :Name( "% of Lead Time" ) ),
				Dispatch(
					"1",
					ScaleBox,
					{Scale( "Log" ), Format( "Percent", 12, 0 ),
					Min( 0.0195073348627051 ), Max( 60.1773644765953 ), Inc( 1 ),
					Minor Ticks( 1 ), Add Ref Line(
						{0, 1},
						"Solid",
						"Black",
						1,
						0.0001
I hope this helps.
~John
Thierry_S
It looks like the HTML version of the graph is backed out where the curve appears in the original version. Have you tried, as an experiment, generate the HTML version without the curve. If it shows properly, there might be something wrong with the background color of the curve. One possible way to resolve this would be to go to right-click on the graph (original), select Customize, and move the curve as far back as possible (just a thought).
Let us know if this works.
Best,
TS
Thierry R. Sornasse
bbass
I went back and remade the graph and put all my distribution charts as local data filters and that seemed to do the trick.
Congratulations on the innovative work-around @bbass .
I'm curious as to what could have caused the area covered by the curve to be blacked out in your original graph. If you could reproduce it with data you can share here, I'd like to look into it. Otherwise, please feel free to send in a request to our technical support so we might be able to fix it for you and anyone else that tries to do the same thing.
Thanks,
~John
bbass
Hi John,
Attached is my original graph and a summarized data table that I used to create it.  Let me know if you need anything else.
Thanks,
Brendon
Hi Brendon,
	V List Box(
		Bivariate(
				Dispatch(
					"1",
					ScaleBox,
						{0, 1},
						"Solid",
						"Black",
						1,
						0.0001
I hope this helps.
~John
