altug_bayram
Level V
Character to DateTime Conversion Help Needed
Hi
I am attaching a sample single row table.
Date1 column is character
e.g. 03-Mar-22 12.13 PM
ie. DD-MMM-YY HH.MM am/pm
Date2 has a datetime format
I need a formula for especially Date1 to convert it into DateTime w/ desired format of
MM/DD/YYYY HH:MM:SS am/pm
(SS, seconds would be automatically zero )
My goal is to update a table based on a second one (or join) once I can 2 comparable datetime columns
note: I tried some attempts, none worked so far. Appreciate the help.
thanks
10 REPLIES 10
altug_bayram
Level V
Re: Character to DateTime Conversion Help Needed
Brady,
It's been long time and I hope you are doing well.
Your technical solution certainly does well, as it did work great. In the end, it was so simple.
thanks again for your support.
