PNash
Changing data type and modeling type for multiple columns?
I have 8 columns that I need to change data type, modeling type, and format on, is there any way that I can do it as a grouping?  Or do I need to write my script for each individual column?
Re: Changing data type and modeling type for multiple columns?
You will need to use a For() loop and loop across the variables in question and change the values.
dt = open("$SAMPLE_DATA/big class.jmp");
colList = dt << get column names(numeric);
For(i=1,i<=n items(colList), i++,
column(dt, colList[i]) << data type("numeric");
Thierry_S
Select all 8 columns, right-click on the header, choose Standardize Attributes, and then choose the attribute you wish to change (e.g. format, modeling type...)
Thierry R. Sornasse
PNash
Is there a way to script that?
An alternate to @txnelson's solution is shown below.  The Get Column Reference message returns a list of references to the columns using the Column() function.  It does not accept the same arguments that Get Column Names does.  Instead, it accepts a list of column names or a matrix.
By using Get Column Names as the argument, you can supply the desired list of column names to Get Column Reference.  Because the resulting list is a list of column references, the Data Type message can be sent to the list.
This example captures a list of column references for all numeric columns in the table and then changes the data type to character.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
//returns {Column( "age" ), Column( "height" ), Column( "weight" )}
colRefs = dt << Get Column Reference( dt << Get Column Names( "numeric" ) );
colRefs << Data Type( "Character" );
I hope this is helpful!
Wendy
