john_madden
Move Selected Columns() with list parameter
If I have a table with five columns:
Column 5Column 3Column 2Column 1Column 4
datadatadatadatadata
and I execute this:
dt = Current Data Table();
dt << Move Selected Columns({"Column 1", "Column 2", "Column 3", "Column 4", "Column 5"}, To first)
then I get this:
Column 1Column 2Column 3Column 4Column 5
datadatadatadata
data
But if I execute this:
dt= Current Data Table();
list = {"Column 1", "Column 2", "Column 3", "Column 4", "Column 5"};
dt << Move Selected Columns( list, To first);
it fails with an "Unrecognized key word" error.
I need to be able to parameterize the column list, as in the second version. How can I make something like the second version work?
pmroz
Re: Move Selected Columns() with list parameter
I tried various flavors of as list(), listeval(), expr, evalexpr(), etc. to no avail.  Had to resort to eval(parse()):
dt = current data table();
alist = {"Column 4", "Column 3", "Column 2", "Column 1"};
clist = char(alist);
col_expr = evalinsert("dt << move selected columns(^clist^, to first)");
eval(parse(col_expr));
gzmorgan0
This is just an alternate method, and FYI.
You can also do this with expressions.  Eval Expr() replaces each Expr() with its value (name expression), and the external Eval() function, executes the command.
Eval( Eval Expr(dt << Move Selected Columns( Expr(list), To first)) );
pmroz
john_madden
Thanks, that works for me!
gzmorgan0
I'm glad to hear a workaround has been found. In the meantime, we reported this issue to development, and JMP 15 (available later this year) has been updated so that the evaluation will happen automatically. Thanks!
