ToddKeebler
Changing Summary Statistics Format of Distribution - JSL
Hi, I think this should be a quickie, but I'm stuck on it: How do I change the format of all the Summary Statistics of a Distribution report at once?
After formatting as I'd like, the auto-generated script shows to change it for every entry of the distribution individually like so:
		Dispatch(
			"Distributions",
			OutlineBox,
			{Set Title( "Summary Data Distribution" )}
		Dispatch(
			{"20 Hz (dB re: 1 kHz)"},
			"1",
			ScaleBox,
			{Min( -10 ), Max( -1 ), Inc( 0.1 ), Minor Ticks( 1 )}
But I'd like to apply it to all of them at once to reduce the code significantly.  I tried sending a set format to the report and a few other things, but none worked.
T
Re: Changing Summary Statistics Format of Distribution - JSL
Try this alternative.
Names Default to Here( 1 );
dist = dt << Distribution( Y( :weight ) );
dist rep = dist << Report;
(dist rep << XPath("//NumberColBox")) << Set Format( "Fixed Dec", 15, 8 );
Just be aware that this simple script assumes that EVERY number column box should be changed.
I am not sure I really understand this request but here goes.
dist rep["Summary Statistics"][NumberColBox(1)] << Set Format( "Fixed Dec", 15, 8 );
ToddKeebler
Hey Mark,
Apologies if my initial question wasn't clear.  I also realized that I didn't copy the important part of the code in the original post.
The code snippet you supplied works well for a single Y column, but what I was looking to do was to change the format of all the Y columns that are included in the distribution with one line of code rather than multiple.  So basically rather than specify "NumberColBox(X)" to change the Xth Y Column, I'd like to just specify something like "NumberColBox" to change all of the Y Columns.
Does that make more sense?
ToddKeebler
Here you can see that I've customized the summary statistics using the following:
SummaryDist << Customize Summary Statistics(
	Std Err Mean( 0 ),
	Upper Mean Confidence Interval( 0 ),
	Lower Mean Confidence Interval( 0 ),
	Minimum( 1 ),
	Maximum( 1 ),
	Trimmed Mean( 1 )
and then I used your code to change the 20 Hz Y column of data to 2 decimal places:
SummaryDistRep["SummaryStatistics"][NumberColBox(1)] << Set Format("Fixed Dec", 15,2);
But the remaining y columns for 20 kHz and Sensitivity haven't had their format changed.
ih
Super User (Alumni) ih
Expanding just a bit on @Mark_Bailey's solution, changing the last line to this would apply this formatting to only items inside outlines boxes called 'Summary Statistics':
(dist rep << XPath("//OutlineBox[text()='Summary Statistics']//NumberColBox")) << Set Format( "Fixed Dec", 15, 8 );
ToddKeebler
Perfect, this works great and seems like this may come in useful in other instances!  Many thanks.
Todd
ih
The last line in here might be what you are looking for:
Names default to here(1);
dt = Open("$Sample_Data/iris.jmp");
	Continuous Distribution( Column( :Sepal length ) ),
	Continuous Distribution( Column( :Sepal width ) ),
	Continuous Distribution( Column( :Petal length ) ),
	Continuous Distribution( Column( :Petal width ) ),
	Nominal Distribution( Column( :Species ) )
//use this to help create XPath queries
dist << Get XML;
//rename some outline boxes
(dist << XPath("//OutlineBox[@helpKey='Distrib Freq']")) << Set title("Freq");
(dist << XPath("//OutlineBox[@helpKey='Distrib Quantiles']")) << Set title("Quant");
//Find all scale boxes from continuous distributions and change the scales
(dist << XPath("//OutlineBox[@helpKey='DistribC']//ScaleBox[@ID='1']")) << {Min( 0 ), Max( 8 ), Inc( 0.5 ), Minor Ticks( 0 )};
