‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
PCameh
Change the default color of box plot lines
I've seen multiple posts related to this topic, but most solutions either direct to use Graph Builder or to temporarily script as a workaround. What I want to know is - if there is a way to set the default color of the box plots in the Variability Chart to black (from the current default red)? I'm using JMP 14.3. Any help would be greatly appreciated!
Change the color of red in the following to black is what I want to accomplish by default:
gzmorgan0
Re: Change the default color of box plot lines
@PCameh ,
You can create a custom Oneway UI.  Try the script below, it calls up the built-in Oneway dialog.  For this script, as long as there are 10 or less category groups all the boxplots will be black. If Big Class.jmp is the current data table and you run this script, use Height and Weight for Y, age for X and sex by BY all your boxplots will be black.
If the JMP table Semiconductor Capability.jmp is the current table and you run this script, use numerous process variables as Y and lot_id as X,
the first 10 boxplots  are black, however, there are 13 lot_id's.
Off the top of my head, I do not have alternate syntax to make this truly flexible. So, one option is to modify this script to accommodate a large number of category values, maybe 100. Then save this script to your main menu, maybe call it my Oneway. Note you can also customize the line width, etc with a few edits to the script.
Oneway(
	Box Plots( 1 ),
	X Axis Proportional( 0 ),
	Points Jittered( 1 ),
		Dispatch(
			"Oneway Plot",
			FrameBox,
			{DispatchSeg( Box Plot Seg( 1 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 2 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 3 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 4 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 5 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 6 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 7 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 8 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 9 ), Confidence Diamond( 0 ), Set Line Color("Black") ),
			DispatchSeg( Box Plot Seg( 10 ), Confidence Diamond( 0 ), Set Line Color("Black") )
12 REPLIES 12
I do not know of any preference that will change the default boxplot color for the boxplot. Other than interactively going into the custom menu and changing the color, the only other way that I know is using JSL to change the Box Plot Segment line color
PCameh
From all the searching I did on the JMP forums, it seems there does not exist an easy way to do this. The only practical solution I found was from @gzmorgan0, in the form of an add-in to change the colors to black after creating a plot: https://community.jmp.com/t5/Discussions/Customize-box-plot-color-in-JMP-preferences/td-p/63157.
While this is incredibly useful, it still requires a key-click (even with a hotkey) after every plot.
Wondering if JMP admins/engineers would know of a workaround...
Add this to the JMP Wish List to make sure it gets directly to the JMP developers
gzmorgan0
@PCameh ,
Oneway(
	Box Plots( 1 ),
		Dispatch(
			"Oneway Plot",
			FrameBox,
gzmorgan0
ps. I agree with @txnelson, being able to set a preferences for a platform BoxPlotSeg would be very nice.
Also, a JSL Dispatch that would allow  a single DispatchSeg( BoxPlotSeg(*), etc.)   or DispatchAllSeg( BoxPlotSeg, etc.) would be a nice solution as well.
PCameh
A million thanks @gzmorgan0!! This is a life-saver hack! I copied your script and replicated the DispatchSeg another 90 times, for a total 100 like you suggested and it works like a charm now! I changed the hotkey to this addin instead of the default JMP Oneway function, and I can't even tell the difference now.
You're the MVP!! Thanks a lot again!
rbfinner
Just implemented the same solution for boxplots in variability charts. I find it makes a big impact, improves legibility, and really helps to highlight differences between groups
Can you share the script for boxplots in variability chart? I am unable to make it happen. Thanks for your help!
Level XI
Following the idea of @gzmorgan0
Names Default to Here(1);
myPlot = Variability Chart(
	Y( :height ),
	X( :age ),
	Variability Analysis( :height, Show Box Plots( 1 ) )
mySegs=report(myPlot)[FrameBox(1)]<< find segs; // get all display elements
Filter Each({seg},(mySegs), (seg<< class name)=="BoxPlotSeg") //just keep the Box Plots
 << Set Line Color("Black")
