Jogger560
Change the default -1 1 coding of categorical variable to 0 1 coding
Dear JMP community,
I found that when fitting a multiple linear regression (y ~ X1 + X2, X1 is a continuous and X2 is a categorical variable), by default JMP defines the dummy variable X2 as -1 1. Is there a way to change it to 0 1, which will be the same as the default dummy variable coding as R? Thanks!
MRB3855
Re: Change the default -1 1 coding of categorical variable to 0 1 coding
Hi @Jogger560 : In the red triangle pull down menu at the top of the Fit Model output, there is an option for Indicator Parameterization Estimates.
10 REPLIES 10
MRB3855
Jogger560
Thanks very much! I also need to get the correlation of estimates under the 0, 1 coding coding, is there a way to do that?
MRB3855
Deleted
MRB3855
Hi @Jogger560 : Hmm, Some JMP folks may want to jump in here but I don't think that is directly available. You can get it yourself though. The Var-Cov matrix of the OLS Estimates is defined on page 8 here.
https://web.stanford.edu/~mrosenfe/soc_meth_proj3/matrix_OLS_NYU_notes.pdf
Advice for coding of factor levels consistently is equivalent-distant, centered on 0.  So -1, 1 for 2-levels, -1,0,1 for 3-levels.
This a quote from Mark Bailey:  Coding benefits the analysis in several ways:
  • The parameter estimates are comparable.They are independent of the associated scale (units).
  • The parameter estimates are interpretable. The intercept when estimated with real values is the response when all your factors are zero. What does that mean? With coding, the intercept is the mean response at the origin (center) of your design. The other parameters still represent the change in the response for 1 unit change in the factor, but in the coded space, 1 unit change is half the range. Double the estimate and that is the change in the response over the full range of the factor.
  • The parameter estimates are uncorrelated or minimally correlated. This preserves power for the significance tests.
MRB3855
Hi @statman : I understood his question to be about the categorial factor (X2 in his OP); you seem to be discussing the covariate X1?
The coding applies to any type of factor in an experiment, continuous or categorical.  This allows for easy comparison of the coefficients for analysis.
MRB3855
Hi @statman : Perhaps, but your first and third  bullets don't seem relevant for X2 categorical.
I just copied and pasted Mark Baileys comments on factor coding...I didn't want to cherry pick what he wrote:
https://community.jmp.com/t5/Discussions/DOE-Code-and-Uncoded-levels-of-factor/td-p/61864
