Kaik
Change , per . in Graph Builder
I am quite new to this as the question denotes. Comp can I replace the , by . in the decimals in the Graph Buider legend? I attach the following example:
I want to write it like: 87.9 not as 87,9. It exist some option in preferences to change that?
Thank you in advance.
Re: Change , per . in Graph Builder
Those are just how your decimals are displayed in JMP.
If you are on windows you have at least these settings (I'm using JMP 17.2 on Windows 10)
https://www.jmp.com/support/help/en/17.2/#page/jmp/windows-preferences.shtml#
https://www.jmp.com/support/help/en/17.2/#page/jmp/mac-os-preferences.shtml# OS seems to have similar settings
