Jackie_
Group values from selected rows
I am trying to group values from the selected rows
Here is the dt:
The final output should look something like this. So combine the Product values with similar percent. Any suggestion?
dt = Current Data Table();
dt << select duplicate rows( Match( :Label, :Percent ) );
Try( dt<< delete rows );
Jackie_
Re: Group values from selected rows
Closing this
Here is one way
aa = Associative Array( :Percent << get values );
For Each( {{key, value}}, aa, aa[key] = dt[Loc( dt[0, "Percent"], key ), "Product"] );
dt << New Column( "Product Code Range", Character, Nominal, <<Set Each Value( Concat Items( aa[:Percent], ", " ) ) );
Try( dt << delete rows );
Jackie_
Closing this
Here is one way
Having done this kind of thing before, I suggest that you round the Percent column before grouping them.  Percent values of .5 and .5001 might be formatted to be displayed as .50 but they will create different groups.  Sometimes I have found that such a script will require not only the rounding, but also the converting to a character column for the code to be robust.
hogi
Level XIII
Nice workaround :)
character "aggregations" like this one - with just a few mouse clicks?
Here is the wish:
https://community.jmp.com/t5/JMP-Wish-List/Summary-and-Tabulate-add-aggregation-option-for-Character...
I do this type of aggregations in JMP using SQL (and like Jim said, converting to characters (or rounding) most likely should be done. One of the reasons being Floating Point Math (30000000000000004.com))
dt = Open("$DOWNLOADS/product_dt.jmp");
dt << New Column("Selected", Numeric, Nominal, Formula(
	Selected()
dt_result = Query(
	Table(dt, "dt"),
SELECT Percent, Label, GROUP_CONCAT(Product, ',') AS Product
FROM dt
WHERE Selected = 1
GROUP BY Percent, Label
