Leonard
Cauchy distribution. Where is Process capability button?
Why where is no Process Capability button? Or you can't do it with Cauchy's distribution data.
Re: Cauchy distribution. Where is Process capability button?
According to the JMP Documentation, the Cauchy distribution has an undefined Mean and Standard Deviation. Based upon that, I assume JMP does not have Cp and Cpk for that distribution and thus no need for the button.
10 REPLIES 10
Leonard
Sorry... Why is there no process capability button?
Leonard
Yes, but then how do I calculate PPK? Should I take the nearest distribution, if it is? Or should I calculate PPK using Standard Deviation? I need to evaluate the process with nonnormal data distribution.
Have you tried fitting all the Distributions, and then determine which have a significant Goodness Of Fit?  You could then use that distribution for your Cp and Cpk
Leonard
yes I click Fit all
And recieve only three, where Cauchy has a priority.
Check out the other fits.....they might give you good estimates
Leonard
but goodness of fit points to Cauchy
Actually, the mean of the Cauchy distribution is defined but not the higher moments. So, no variance, no standard deviation. No standard deviation, no Ppk.
Kevin_Anderson
And, just as an aside, if you're responsible for improving a process that outputs data that are really Cauchy distributed, you might want to update your resume...
