Leonard
Cauchy distribution. Where is Process capability button?
Why where is no Process Capability button? Or you can't do it with Cauchy's distribution data.
10 REPLIES 10
shampton82
Level VIII
Re: Cauchy distribution. Where is Process capability button?
Is this count data?  If so a couple of ideas: You could turn it into pass/fail based upon your defect limit then convert your defect rate to a Ppk from a sigma-DPMO-Ppk table.  You could also fit it as Poisson and use the distribution profiler to determine what your DPMO rate was (by setting the x axis to your spec limit and using the returned Y value) and convert that into a Ppk. The other option would be to turn your zero's into 0.0001's and then you'll have some additional distributions you can fit.
