Knekse
Capability from a bivariate regression
Hi
I read this post by Phil Kay, and it helped we some of the way towards my goal:
https://community.jmp.com/t5/Discussions/Tolerance-Interval-for-Regression/m-p/302845
Would it also be possible to calculate an expected capability from a bivariate regression, if I have a lower and upper spec limit?
Example: I have data measured for and Response(Y) at several different temperature levels (X) and I want to predict what the capability of the response is at a higher temperature.
Knekse
Re: Capability from a bivariate regression
I was just sitting here, looking at the numbers, and maybe I have an idea. What if:
  1. I use the regression line to calculate the Response(Y) at the higher temperature (let's say 60degC):  Y(60)
  2. I "transform" my spec limits to a set of spec limits for the residuals: Ymin - Y(60) and Ymax - Y60)
  3. Now, I can calculate the capability with the "residual spec limits"
Or, something completely different? :)
P_Bartell
Level VIII
Here's what I suggest: Recreate the model in the Fit Model Standard Least Squares platform, then use the simulation capability within the Prediction Profiler to simulate the response for assumed variances of the x values. From there lots of options to export the simulated predictions to the Capability platforms in JMP for additional analysis and visualizations.
Knekse
Hi P_Bartell
Thank you for the suggestion. In my case, I want to fix the x value (at an extrapolated point) and estimate the mean and variance at this point, and thus the capability. So I am not sure you suggestion would serve the purpose, as I want to see the variation in the other dimension than you suggested. Or?
P_Bartell
Level VIII
The simulator allows you to set any independent variable at any mean and estimated variance. So even if your x set point is extrapolated from your empirical space...the simulator will still work.
Knekse
I still think that it's not what I am looking for. Allow me to elaborate
I can fit a model to my Response as a function of the temperature:
But I would like to calculate: If I fix the temperature to 80 degrees, what will the distribution of the response be?
