The Count of the Samples can be indirectly calculated. The count is not specified, but the Portion is specified. So if the N is multiplied by the Portion value, you will get the Count of the Samples.
Interactively, this can be done by right clicking on the table and selecting Make into Data Table. Then simple create a new column in the new data table, and specify the formula
% Actual * xxxxx
where xxxxx is the value of N from the Summary Statistics paragraph
The following is an example of scripting what you want:
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
dt << dis = Distribution(
Continuous Distribution( Column( :PNP3 ) ),
SendToReport( Dispatch( {"Distributions", "PNP3", "Capability Analysis"},
" Long Term Sigma", OutlineBox, {Close( 1 )} ) )
// Create the new data table
dtstats = Report( dis )["Capability Analysis"][1] << make into data table;
// Strip off the N value from the Summary Statistics table
Count = (Report( dis )["Summary Statistics"][1][1][2] << get)[6];
// Create the new column
dtstats << New Column( "Count of the Samples", formula( :Name( "% Actual" ) * count ) );
// Delete the formula to convert the results from virtual values to real values
dtstats:Count of the Samples << delete property( "Formula" );
