Can the X group name text orientation of this Graph Builder be set to vertical?
lala
Level VIII
ca="tem";New Column(ca);Column(ca)<<Formula( char(age)||"longlong" );dt<<run formulas;Column(ca)<<deleteFormula;
p1 = dt << Graph Builder(
	Size( 300, 400 ),
	Legend Position( "Inside Bottom Right" ),
	X Group Edge( "Bottom" ),
	Variables( X( :weight ), Y( :height ), Group X( :tem, Size( 161 ) ), Color( :sex ) ),
	Elements( Bar( X, Y, Legend( 5 ), Response Axis( "X" ) ) ),
		Dispatch(
			"weight",
			ScaleBox,
			{Label Row(
				{Automatic Tick Marks( 0 ), Show Major Labels( 0 ), Show Major Ticks( 0 ),
				Show Minor Ticks( 0 )}
		Dispatch(
			"height",
			ScaleBox,
			{Label Row(
		Dispatch( {}, "X title", TextEditBox, {Hide( 1 )} ),
		Dispatch( {}, "Y title", TextEditBox, {Hide( 1 )} )
lala
Level VIII
回复: Can the X group name text orientation of this Graph Builder be set to vertical?
  • It's not perfect
Re: Can the X group name text orientation of this Graph Builder be set to vertical?
Seems like only Y Group has an option to change the level orientation
lala
Level VIII
If there are too many categories of X, can you add a slider to adjust the range of data that needs to be mapped?
I used this option in JMP 14, changing the parameters so that only the left one appears
lala
Level VIII
A slider such as data can change the scope of the selection, and can also change the number of rows selected.
You can most likely use Local Data Filter for that
