chlnho
Can't change all marker size in Graph Builder by script
Hi all,
My JMP is 9.0.0 64 bit windows edition.
I have a problem to adjust the marker size by script in the graph builder. I try to use the following code to change all marker size and frame size for every frame box. All frames are reszied corrrectlly but the frame's marker size are not. Only FrameBox(1)'s marker size is changed. I'm trapped in this problme for a couple of days. Any suggestion is appreciated, thanks a lot!
GR = Graph_Builder_1 << Report;
GR << Dispatch( {}, "Graph Builder", Frame Box, {Marker Size( 4 )} );
GR << Dispatch( {}, "Graph Builder", Frame Box, {Frame size( 250, 250 )} );
ms
Super User (Alumni) ms
Re: Can't change all marker size in Graph Builder by script
Seems like a bug that the message is not inherited by all Frameboxes.
Every FrameBox needs its own message, at least when it comes to Markes Size. This can be done with a loop as in the example below:
dt = open("$sample_data\Big Class.jmp");
gb=Graph Builder(
          Variables( X( :weight ), Y( :height ), Group Y( :sex ) ),
          Elements( Points( X, Y, Legend( 1 ) ) ),
summarize(g=by(:sex));
for(i=1, i <= nitems(g), i++,
report(gb) << Dispatch( {}, "Graph Builder", FrameBox(i), {Marker Size( 4 )} )
pmroz
That syntax looks OK.  But, how about just setting the marker size when you create the graph builder graph?  This works:
Graph Builder(
      Variables( X( :weight ), Y( :height ) ),
      SendToReport( Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 4 )} ) )
chlnho
Hi PMroz,
   Thanks for the reply, it still doesn't work when number of the frame boxes > 1, for your example, if we add column :sex to Group Y, we got two scatter plot, only the first framebox's marker size are changed.
Graph Builder(
ms
gb=Graph Builder(
chlnho
Hi MS,
  It works by sending message to every frame box, thank a lot!
