asvp
Generating Generalized Gamma Distribution using JMP scripts
All,
Is there a function that would allow generating random numbers
from a generalized gamma distribution? Scripting guide has
function random gamma for generating random numbers from
Gamma distribution but I don't see anything for generalized gamma
distribution.
Thanks for your help.
-ASVP
ms
Super User (Alumni) ms
I don't think you can get random numbers for a three-parameter generalized gamma distribution using the builtin generators. If it's possible I would also like to know how to do it.
However, JMP 9  can get random numbers from R. See JSL example below.
// Function that returns random numbers from
// generalized gamma distribution generated
// by R package VGAM
rgengamma = Function( {n = 100, b = 1, d = 1, k = 1},
  R Init();
  R Submit( "
library(VGAM)
rggam <- rgengamma(100,1,2,3)
  rggam = R Get( rggam );
  R Term();
  rggam
// Example of how touse the function to populate a
// data table with n=100 random numbers
dt = New Table( "Generalized Gamma", New Column( "Random" ) );
Column( dt, "Random" ) << setvalues( rgengamma( 100, 1, 2, 3 ) );
mattf
Level V
Hi:
MS gave us a clue.  From the R prompt:
>library(VGAM)
>rgengamma
and
>?rgengamma
reveals that the rgengamma returns a modified base R rgamma function
y = rgamma(n, k)
scale*y^(1/d)
In JMP, we can also use a modification of the basic "Random Gamma" function, e.g.
Current Data Table() << New Column( "JMP GenGamma",
     Formula( 1*Random Gamma( 1 )^(1/2) ) );
     Current Data Table() << Run Formulas;
(Of course, one will have to fiddle with the parameters to get a match)
Matching random number generators, anyone - perhaps by fixing seeds?
Best regards,
-Matt
Best
asvp
Thanks Matt and MS for showing a way to generate random numbers from
generalized gamma distribution.
Regards,
-ASVP
