lala
Level IX
Can JMP graphics have this effect?
This is the HTML effect.
Can JMP graphlet achieve this effect?
Thanks!
23 REPLIES 23
Craige_Hales
Re: Can JMP graphics have this effect?
you can use function arguments instead of x,y
New Window( "Example",
	trapx = 20;
	trapy = 50;
	handx = 70;
	handy = 80;
	trapcolor="blue";
	handcolor="blue";
	Graph Box(
		Frame Size( 200, 200 ),
		handle( handx, handy, // any handle(s) must come before Mousetrap
			Function( {a, b}, handx=a; handy=b;
				Write( Eval Insert( "\!nhand drag ^a^ ^b^" ) );
				handcolor="magenta"; )
		, // the mouse-up handler
				Write( Eval Insert( "\!nhand release ^a^ ^b^" ) );
				handcolor="cyan"; )
		Mousetrap( // should not be more than one Mousetrap, the first one captures all clicks
			Function( {a, b}, trapx=a; trapy=b;
				Write( Eval Insert( "\!ntrap drag ^a^ ^b^" ) );
				trapcolor="red"; )
				Write( Eval Insert( "\!ntrap release ^a^ ^b^" ) );
				trapcolor="green"; )
		// the drawing occurs outside of the mousetrap or handle
		pencolor(trapcolor);
		pensize(3);
		Circle( {0, 0}, Sqrt( trapx * trapx + trapy * trapy ) );
		pencolor(handcolor);
		pensize(3);
		Circle( {0, 0}, Sqrt( handx * handx + handy * handy ) );
If you need one or more handles, they must appear before the mousetrap because a click will be consumed by the mousetrap if no previous handle took it.
Craige
hogi
Level XIII
Interesting. Why is the handle not tied to the x/y coordinate system?
It still works after resizing the plot, but there is a significant offset:
(view in My Videos)
Craige_Hales
The handle is. The circle is not. I *think* the perfectly round circle on the non-square grid has its radius defined in Y axis coordinates.
Craige
hogi
Level XIII
Ouch, sure  - How Do You Draw a Circle?
hogi
Level XIII
@hogi wrote:
How do I access this namespace?
Both:
Report(gb)[FrameBox(1)]  << get namespace() ;
(Report(gb)[FrameBox(1)] << find seg(TopSeg (1))) << get namespace();
produce a new namespace.
... I asked JMP support: TS-00173810
unfortunately:
You cannot access the graphics script namespace externally.
hogi
Level XIII
lala
Level IX
Looks like adding a hover drill script.
For(iFrame=1,iFrame<=N Items(framelist),iFrame+=1,frame=framelist[iFrame]; Eval(Eval Expr(frame<<Addgraphicsscript(Mousetrap({},
Thanks Experts!
Slightly changed the script to display weight values instead of more:
names default to here(1);
gb = dt << Graph Builder(
	Show Control Panel( 0 ),
	Variables( X( :height ), Y( :weight ), Overlay( :sex ) ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
fb = Report( gb )[FrameBox( 1 )];
xx = yy = 0;
valuesMatrix = :height << Get Values; //***new*** Get column values for height
fb << addgraphicsscript(//
	Mousetrap(
		xx = x;
		yy = y;
	V Line( xx );
	// at this point you can highlight all the values near xx
	For( irow = 1, irow <= N Rows( dt ), irow += 1,
		If( Abs( dt:height[irow] - xx ) < 0.5, // big class height step is 1, <.5 selects a single column of weights
			Marker( Marker State( 4 ), {dt:height[irow], dt:weight[irow]} )
	valuesRows = char(:weight[loc(valuesMatrix,round(xx))]); //***new*** write to char weight values for all rows of height at position round(xx)
	xwidth = X Range();
	xmidpoint = X Origin() + xwidth / 2;
	If( xx < xmidpoint,
		Text( {xx + xwidth / 100, yy}, "height " || Char( Round( xx ) ) || "\!nweight " || valuesRows  )////***new*** exchanged "more" with weigth and list of weight values for that location of height
		Text( right justified, {xx - xwidth / 100, yy}, "height " || Char( Round( xx ) ) || "\!nweight " || valuesRows )
you may even could add sorting the values ascending/descending.
(view in My Videos)
/****NeverStopLearning****/
hogi
Level XIII
Hm, I think many of my conclusions were wrong.
Another try:
  • Maybe the hogi_2-1766581578282.png does not mean  "after running the [drag] script" but rather "with the mouseUp".
  • And very important. If there is no need to update a Framebox, it doesn't get updated.
So,
  • when the mouse is moved, new coordinates are saved to x & y
  • hogi_4-1766582607718.png? No - in the Here namespace because we used Names default to HERE (1))
  • ... and the values can be used within the Here namespace - even outside of the Mousetrap(). This puzzled @Craige_Hales , and I put another foot into this trap: Making-a-drag-amp-drop-script
  • After the update of the variables, JMP gets a trigger to redraws THE Framebox with the graphics script and the current x and y values.
  • Other Frameboxes don't get updated:
    If we move the mouse in the left frame box, the center one is not updated – and vice versa.
    This creates the illusion of two separate namespaces. So it's no wonder that users can't access the namespace of a frame box — there isn't one. It's just the shared Here namespace in combination with local Framebox updates.
  • After releasing the mouse button, x and y  hogi_1-1766581375816.png.
    However, no update of the frame boxes is triggered. Therefore, the user does not notice this reset of the variables in the Here' namespace.
  • Just when the graph gets updated the next time (e.g. resized, or some data points selected), the graphics script is executed again and reveals that the values were reset (some time ago).
(view in My Videos)
hogi
Level XIII
gpt-5.6-luna.
remindet me of this post
not bad!
