Hello, I've been struggling trying to make something like the Drag & Drop interfaces used in (JMP Pro) SEM and Reliability Block Diagrams.
The idea is to have a pallet of "boxes" down the left side of the screen. I want to grab one of the boxes, drag it into the center area of the screen, drop it, then go grab another box, drag & drop, etc.
I've tried several ways, including handles and mousetraps. I can get part of the way, but not all the way.
My latest code is shown below, using Mousetrap. I can grab the box in the upper left of the GraphBox, and drag it around the screen, and drop it where I want it. (It turns black when it is dropped.) But then I can't go grab another box. I can only move the box I just dropped. I cannot add another box.
I'm currently building this as an Application, but happy to change that if it helps.
Script below shows what I've coded in Application Builder. Attached file contains the entire application.
I fear there are aspects of Mousetrap and GraphBoxes and Add Graphics Scripts that I just don't grasp. Can anyone help?
// This script is executed when a new module instance is
// created. The pre-defined object "thisModuleInstance" refers
// to the instance object, but other objects such as boxes and
// scripts have not yet been created. Variables declared here are
// scoped to the ModuleInstance namespace.
// This special function will receive parameters passed to CreateInstance()
OnModuleLoad({},
thisModuleInstance << Create Objects;
// After this point your module instance objects have been created
// and can be referred to by name (for example, "Button1").
x0=5;
y0=95;
winref = (this module instance << Get Box);
// set graph box scales
winref[framebox(1)] << xaxis(0,100);
winref[framebox(1)] << yaxis(0,100);
// draw box in upper left corner.
pen color("Green");
winref[framebox(1)] << add graphics script(
pen color("Green");
Line({0,90}, {10,90},{10,100}, {0,100},{0,90}));
winref[framebox(1)] << Add Graphics Script(
Mousetrap(
// drag script (mouse down)
// if mouse location is within box in upper left corner, then OK to drag.
if(
and(
x>=x0-5,
y>=y0-5,
x<=x0+5,
y<=y0+5
// set x0 and y0 if that were true
x0 = x;
y0 = y;
// redraw the box at current mouse location while mouse button is down
"Front",
pen color("Green");
Line({x0-5, y0-5}, {x0+5, y0-5}, {x0+5, y0+5}, {x0-5, y0+5}, {x0-5, y0-5}));
// mouse up script
// draw a polygon centered at the current mouse location
polygon({x0-5,y0-5},{x0+5,y0-5},{x0+5,y0+5},{x0-5,y0+5},{x0-5,y0-5})
// at this point I want to manually reposition the mouse over the original box in the
// upper left, and grab another box.
// Instead, all I can do is grab the box I just created and drag it somewhere else.
