You could do trial-and-error, but that would be tedious. The only other way that I can see to do this is to fit a distribution to the data, and then use the Quantile Profiler with a desirability function to find the quantile level. For the situation you proposed, I fit a smooth curve to the data and the results looked like this:
![Big Class - Distribution of weight.png Big Class - Distribution of weight.png](https://community.jmp.com/t5/image/serverpage/image-id/60504i4134D9BE5D03DCB9/image-size/large?v=v2&px=999)
Of course different distributions will give slightly different results, but it is the only way that I can see to determine the proper quantile level.
Since you had results in a script, here is the script to match my results:
Distribution(
Continuous Distribution(
Column( :weight ),
Fit Smooth Curve(
Quantile Profiler(
1,
Confidence Intervals( 1 ),
Desirability Functions( 1 ),
Smooth Curve Quantile <<
Response Limits(
{Lower( 38.2411401370744, 0.0183 ), Middle( 115, 1 ),
Upper( 200, 0.0183 ), Goal( "Match Target" ), Importance( 1 )}
Term Value(
Probability(
0.685484294268159,
N Levels( 200 ),
Lock( 0 ),
Show( 1 )
Dispatch( {"weight"}, "Quantiles", OutlineBox, {Close( 1 )} ),
Dispatch( {"weight"}, "Summary Statistics", OutlineBox, {Close( 1 )} )
Dan Obermiller
