josephc
Calculation for predicted response for RMSE in DOE
Hi Everyone,
I am new to DOE and I am wondering, how does JMP calculate the the predicted response for the predicted plot when analyzing DOE data?
Thanks
Re: Calculation for predicted response for RMSE in DOE
The predicted values are calculated using the regression equation that has been fit to the data. You can find the equation under Red Triangle > Estimates > Show Prediction Expression. You also can save the equation as a formula column to your data table (Red Triangle > Save Columns > Prediction Formula) to obtain the predicted values for each observation. Right click on the new column header and select Formula to view the formula, which will match the Prediction Expression. All the regression coefficients you see will match the estimates in the Parameter Estimates section of the Fit Model report.
Ross Metusalem
JMP Academic Ambassador
Ross Metusalem
