fat_angus
Calculation a p-value in a data table (regression) using row formulae
Background: Suppose I have rows of x, y data (SN_C, Value [Sigma Units]) as shown in attached file but also pasted below.
Slope_8 is calculated from the previous 8 [x.y] values.
I want to compare the slope_8 value to the null hypothesis for linear regression (slope =0) and provide a p-value. Is there an easy way to do this?
The formula for the slope 8 was taken from these discussion boards (@txnelson, @Mark_Bailey)and does exactly what I want after I did simple modification to use N=8
If( Row() > 7,
	x = J( 8, 1, 1 ) || :SN_C[Index( Row() - 7, Row() )]`;
	y = :"Value (Sigma Units)"n[Index( Row() - 7, Row() )]`;
	(Inv( x` * x ) * x` * y)[2];
I know I should know how to do this and my apologies for being too stupid to figure it out. Its been 30 years since I've taken matrix algebra :)
Re: Calculation a p-value in a data table (regression) using row formulae
I think you can get what you want from the Linear Regression() function.  Take a look in the Scripting Guide for the definition and example of how to use it.  Below, I created 2 new columns, "New Slope" and "PValue".  I set the format for the PValue column to "PVALUE".  I then set the formula for the PValue column to
If( Row() > 7,
	x = dt[Index( Row() - 7, Row() ), 2];
	y = dt[Index( Row() - 7, Row() ), 3];
	{Estimates, Std_Error, Diagnostics} = Linear Regression( y, x );
	:New Slope[Row()] = estimates[2];
	diagnostics["p_value"][1];
Here is the display
If( Row() > 7,
	:new slope[Row()] = estimates[2];
If( Row() > 7,
Here is the display
If( Row() > 7,
fat_angus
txnelson... thanks so much. This was exactly what I was looking for. I sincerely appreciate this.
