bio_grad
Calculating linear regression slope in formula
I was wondering if there was a way to calculate the linear regression slope of column data within a data table formula.
A simple example of the table is below. The data is ordered and I would like to calculate the slope of a fit line of volume over time using the current row's data and previous points to perform the regression.
The idea is that I would like to see the how the calculated slope changes with increasing the number of data points. From doing this manually, the slope values end up approaching a given value and stay within +/-5% after 20 or so points.
InstanceTime (s)Volume (mL)Slope (mL/s)
100n/a
250.5m1
3100.8m2
NTVmN-1
If that is possible, my next challenge would be to set this up so that I can calculate the slope formula so that it uses N data points on either side of the current row for a symmetrical moving calculation instead.
Thank you in advance.
25 REPLIES 25
fat_angus
Re: Calculating linear regression slope in formula
This is interesting.. if I wanted to apply a p-value to this... based on null hypothesis (slope = 0)... is there a way to integrate this into forumula?
In other words, I would like to see when the moving slope is changing significantly based on confidence interval around slope
HydroBug
Fantastic solution to EXACTLY what I wanted to do.  Thank you!!
altug_bayram
Folks interested in this problem may want to consider supporting the wish idea:
https://community.jmp.com/t5/JMP-Wish-List/Moving-Rolling-Window-Statistics/idi-p/722620
rdzdec
You mention a "span of 3", if we want to modify it to be moving slope of "N" samples, which value will need to change?
mksaad
@Mark_Bailey Hi mark, I am new to JMP and am trying to do something similar to bio_grad where I perform linear regression on 3 points, then 4 points, then so on in a column in my data table. I am trying to understand what your answer is actually doing and had a couple of questions. What does || mean? also what is J?
J() is a function that creates a matrix of identical values.  The default is 1.
|| is an operator that indicate concatenation.  So in Mark's example he is concatenating 2 matrices.
These functions and operators are fully documented in the Scripting Guide
     Help==>JMP Document Library  …..  Scripting Guide
