Françoise
Bug with publish file
see the 2 images.
when I 've made a publish file, there was a pb with a curve (blue and red for the 5th curve).
a solution?
best regards
Capture Graph BuilderCapture Graph Builder
Capture HTMLCapture HTML
Re: Bug with publish file
Hello, would you be able to share the data and script used to create this report, so I could look into the problem?  If you are unable to share the data, perhaps saving the JSL used to create the report would allow me to try to recreate the problem with similar types of data using sample data.
Françoise
hi, can you give me a private mail to send you data and jsl?
or  I can show you with teams.
best regards
Jeff_Perkinson
@Françoise, if you're unable to post a sample here to demonstrate the problem, please contact our Tech Support department ([email protected]). They can help you. Our development staff is not able to respond privately here or provide support via email.
Thanks!
-Jeff
