ashwint27
Broadcast "Save Transformed" in Distributions platform
From the Distribution platform, I have a Continuous Fit >> Fit SHASH report with 60 analyses in one output.  I would like to do a bulk/broadcasted Red Triangle > Save Columns > Save Transformed, which should result in 60 new columns in my data table, each with its own respective SHASHTrans formula.  Broadcasting does not seem to work.  Is there a good way to accomplish this?
Re: Broadcast "Save Transformed" in Distributions platform
To follow up @jthi Broadcasting the Save Transformed using the CNTL key as you select the Save Transformed option works in JMP 19.
Which JMP version are you using? For me the broadcasting works fine with JMP18 (holding ctrl and not relying on auto-broadcast, not sure if that works). How are you doing your analysis? Are you using By column or separate columns for each analysis?
