Polygon0516
Blank Tabs in JMP Project
I'm working in a JMP project, and I am seeing tabs open at the top that when I click on them, they are completely blank (grey screen). When I click the correlating file name in the Contents window on the left side, it opens up the file. I've tried re-hiding, closing, and deleting the file with the same name as the blank tab, but the blank tab is still there.
Can someone please share why this is happening & how I can get rid of the blank tabs to de-clutter the top of my project?
Thank you!
Re: Blank Tabs in JMP Project
Hi @Polygon0516 ,
Could you provide screenshots (or better yet, a project file) to show what you're experiencing? It's also worth emailing [email protected] if you suspect this is a bug.
Thanks,
Ben
