AKARI
Bivariate Analysis, how to edit graph
The number of the right dates are smaller than left one.
So, as you can see the points are lining on right side and they are hidden.
Could you tell me how to move the position.
WebDesignesCrow
Re: Bivariate Analysis, how to edit graph
Hi @AKARI ,
To disable the X-axis proportional, you can click the red triangle -> display options -> untick X-axis proportional
Additional reference can be found here
https://community.jmp.com/t5/Discussions/Oneway-Plot-x-axis-spacing/td-p/193419
Alternatively, you could just put your cursor on the right-side of the axis when it is the hand tool (or grabber) and drag to the left.
(view in My Videos)
Dan Obermiller
