Level XIII
Binning by Spec limits
If I have a column with spec limits defined as column properties, is there a "one-click" solution *) to bin the data into 3 groups:
x < LSL
LSL <= x <= USL
x > USL
Re: Binning by Spec limits
I was able to create a grouping based upon the binning of the Spec Limits
Using the Levels option, and specifying Create Transform Column
I simply created the following formula to create the binning
and it worked as desired.
In my example, I used the Semiconductor Capability sample data table, and the PNP3 column.  It has outliers, however, it has no outliers that are less than the LSL value, so I manually changed one row to have a low value, just to test the formula.
specs = :PNP3 << get property( "spec limits" );
If(
	:PNP3 < specs["LSL"], -1,
	specs["LSL"] <= :PNP3 <= specs["USL"], 0,
	1
Here is an example of one way to handle this
dt = // Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
dt << New Column( "bin",
	formula(
		As Constant( specs = :PNP3 << get property( "spec limits" ) );
		If( specs["LSL"] <= :PNP3 <= specs["USL"],
			1,
			0
Level XIII
Thanks @txnelson for the JSL example :)
The disadvantage: a new column is added.
If I do this for all column, it gets quite crowded.
I hope a similar functionality is directly implemented in Jmp - but couldn't find it.
neither here:
nor here:
Is it hidden behind a Shift/Alt/Ctrl Click?
If(
	1
Level XIII
So, there is no single click solution?
I also checked the Custom Binning menu.
Several options are listed, but none to use the spec limits:
