miguello
Best way to plot GraphBuilder plot with multiple Y variables using JSL
All,
I'd like to ask for an input on the best way to script a GB plot with multiple parameters.
Let's say I have a table like this:
New Table( "Untitled 140",
	Add Rows( 12 ),
	New Column( "Category",
		Character,
		"Nominal",
		Set Values( {"A", "A", "A", "B", "B", "B", "C", "C", "C", "D", "D", "D"} )
	New Column( "Value1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [1, 4, 2, 3, 6, 2, 3, 5, 4, 1, 3, 6] )
	New Column( "Value2",
		Numeric,
		"Continuous",
		Set Values( [6, 3, 5, 2, 8, 6, 5, 2, 6, 3, 5, 4] )
And I want to script a plot like this:
where the autogenerated script looks like this:
Graph Builder(
	Size( 522, 450 ),
	Show Control Panel( 0 ),
	Variables( X( :Category ), Y( :Value1 ), Y( :Value2, Position( 1 ) ) ),
	Elements( Bar( X, Y( 1 ), Y( 2 ), Legend( 4 ), Summary Statistic( "Range" ) ) )
with the catch that there is an arbitrary number of Y columns and the names are also arbitrary.
For plots like Variability plot I would something like this:
parameters = {:"Value1"n, :"Value2"n};
yExpr = Expr( Y() );
For Each( {value, index}, parameters, Insert Into( yExpr, Name Expr( value ), 1 ) );
Eval(
	Substitute(
			Expr(
				Variability Chart( placeholder, X( :Category ),  Std Dev Chart( 0 )  )
		Expr( placeholder ), Name Expr( yExpr )
where I receive the names of the columns as a list and then construct a Y expression and then put it into the script for the chart. It would give me a list of variability plots, but that's OK with me.
If I want to take the same route in case of the GB it looks like I will have to construct two expressions:
and
Which is essentially the whole script.
My question: Is there a better way rather than making bunch of substitutions with expressions to assemble those two lines?
Thanks!
6 REPLIES 6
miguello
Re: Best way to plot GraphBuilder plot with multiple Y variables using JSL
Ok, this is how I solved it, but is there a simpler way? Can't believe that to script such a simple thing I need to go into that kind of complexity...:
yExprPos = Expr( Y( Position( 1 ) ) );
barExpr = Expr(
	Bar( X, Summary Statistic( "Range" ) )
yNExpr = Expr( Y() );
variablesExpr = Expr(
	Variables( X( :Category ) )
	Insert Into( yExpr, Name Expr( value ), 1 );
	Insert Into( yExprPos, Name Expr( value ), 1 );
	Insert Into( variablesExpr, Name Expr( yExprPos ) );
	//This is for Y(1) etc. in Bar()
	Insert Into( yNExpr, Name Expr( index ) );
	Insert Into( barExpr, Name Expr( yNExpr ), 2 );
//Name Expr( yExpr );
Show(Name Expr( variablesExpr ));
Show(Name Expr( barExpr ));
gbExpr = Expr(
	Graph Builder( Size( 522, 450 ), Show Control Panel( 0 ), placeholder1, Elements( placeholder2 ) )
Eval(
	Substitute(
		Substitute(
			Name Expr(gbExpr),
			Expr( placeholder1 ),
		Expr( placeholder2 ),
I have usually used similar methods as you to build such graph builders, this might be a good readRe: Can you construct this without writing expression a string?
ih
Super User (Alumni) ih
This still uses loops to build those expressions, but it concatenates lists of arguments instead of substituting them:
Names default to here(1);
//call another function (f) with the arguments provided in a list (l)
do.call = function({l,f},
	Substitute(
		Name Expr(l),
		Expr({}),
		Name Expr(f)
dt = New Table( "Data",
	Add Rows( 12 ),
	New Column( "Category", Character, "Nominal",
	New Column( "Value1", Numeric, "Continuous", Format( "Best", 12 ),
	New Column( "Value2", Numeric, "Continuous", Format( "Best", 12 ),
vars = {:Value1, :Value2};
VarExpr = do.call(
	{ X( :Category ) } || transform each({v}, vars, eval expr( Y( Expr( Name Expr( v ) ), Position( 1 ) ) ) ),
	expr(Variables())
BarExpr = do.call(
	{ X } || transform each({v, i}, vars, eval expr( Y( Expr( i ) ) ) ) || { Legend( 4 ), Summary Statistic( "Range" ) },
	expr(Bar())
Eval( Eval Expr(
	dt << Graph Builder(
		Size( 522, 450 ),
		Expr( Name Expr( VarExpr ) ),
		Elements( Expr( Name Expr( BarExpr ) ) )
pmroz
Don't forget the STACK command.  Requires eval(parse()) but it's pretty clean otherwise.  Here's an example with three columns to be plotted.
dt = New Table( "Test",
	Add Rows( 12 ),
		Character,
		"Nominal",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
	New Column( "Value3",
		Numeric,
		"Continuous",
		Set Values( [1, 4, 3, 6, 5, 7, 3, 4, 2, 8, 6, 1] )
dt_cols = dt << get column names(string);
removefrom(dt_cols, 1);	// Remove Category
// Create the list of columns, like this: ":Value1, :Value2, :Value3"
col_list = ":" || concat items(dt_cols, ", :");
stack_str = evalinsert(
"\[dts = dt << Stack(invisible,
	columns( ^col_list^ ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ))]\");
eval(parse(stack_str));
dts << Graph Builder(
	Size( 518, 448 ),
	Variables( X( :Category ), Y( :Data ), Overlay( :Label ) ),
	Elements( Bar( X, Y, Legend( 7 ) ) )
ih
@pmroz here is the same code without Eval(Parse()).  I agree this is much cleaner!
	Add Rows( 12 ),
		Set Values( {"A", "A", "A", "B", "B", "B", "C", "C", "C", "D", "D", "D"} ) ),
		Set Values( [1, 4, 2, 3, 6, 2, 3, 5, 4, 1, 3, 6] ) ),
		Set Values( [6, 3, 5, 2, 8, 6, 5, 2, 6, 3, 5, 4] ) ),
	New Column( "Value3", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 4, 3, 6, 5, 7, 3, 4, 2, 8, 6, 1] ) )
dt_cols = dt << get column references();
remove from(dt_cols, 1);	// Remove Category
	columns( dt_cols ),
	Size( 518, 448 ),
pmroz
Nice!  Thanks for adding that touch.  Wish I'd have tried that myself!
