Maerawlings
How to center columns in Tabulate?
Hello All!
I am a fairly new user and would love to know if we can center the columns when we are using the "Tabulate" function.
I have tried:
- highlighting/right clicking
- adjusting the properties to "center"
- looking at the format settings
- input "center" into the "Set Format( Uniform Format ( 10, 1 ) )" and adding ",center"
- looking at my overall JMP preferences-->Tables
Thank You!
Re: How to center columns in Tabulate?
Welcome to the Discussion Community.
I am not a Super User of Tabulate, so I may not be totally correct in my answer.  I checked through all of the messages available to Tabulate (See Scripting Index) and couldn't find anything that would allow the changing of the alignment for the Tabulate cells.
I suggest that you add your ideas to the JMP Wish List
So I have found a kluge of a work-around.  Table Boxes, and their StringColBox() columns do allow justification.  Below is a sample sccript that shows the concept.
names default to here(1);
dt=// Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "$SAMPLE_DATA/big class.jmp" );
// Create the Tabulate Table, and save it as a data table
(tab = dt << Tabulate(
	Change Item Label( Statistics( Mean, "height" ) ),
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Statistics( Mean ), Analysis Columns( :height ) ),
		Row Table( Grouping Columns( :age ) )
) )<< Make Into Data Table;
// Close the
thetable =  current data table();
tab << close window;
// Only character fields can be justified, so change the 2 numeric columns to character
thetable:age << data type(character);
thetable:"height(height)"n << data type(character);
// Move the table to a journal, and close the table
thetable<<journal;
close(thetable, nosave);
// Center the fields
jr=current journal();
jr[StringColBox(1)]<<set justify("center");
jr[StringColBox(2)]<<set justify("center");
