Dennisbur
Begin Data Update
Hello
I have a table and would like the empty volume to be updated to 0
I have written the script to update the column "19-04-2024"
the problem is the name of the column can be changed and I prefer to use column (3) or column (4)
but it doesn't work.
can you please correct the script?
dt << Begin Data Update;
                                    dt << Recode Column (
                                    dt << Column (3),
                                   {Map Value( _rcOrig, {., 0}, Unmatched( _rcNow ) )},
                                   Update Properties( 1 ),
                                   Target Column(Column (3) ) );
dt << End Data Update;
12 REPLIES 12
Re: Begin Data Update
AsColumn seems to work here
dt[1::10, 4] = .;
dt << Recode Column(
	AsColumn(dt, 4),
	{Map Value(_rcOrig, {., 0}, Unmatched(_rcNow))},
	Update Properties(1),
	Target Column(AsColumn(dt, 4))
This is simple case where I would most likely use data table subscripting Data table subscripting
dt[1::10, 4] = .;
missing_rows = Loc(dt[0, 4], .);
dt[missing_rows, 4] = 0;
Dennisbur
it's something wrong
I tried to use the simple script to change empty volume to 0 in column "19-04-2024"
dt[1::10, 3] = .;
missing_rows = Loc(dt[0, 3], .);
dt[missing_rows, 3] = 0;
but I see the script change not just empty value to 0, the script change 14.3% and 21.3% to 0 too
actually my script is working well, but I don't know how I can change dt :"19-04-2024" to "column 3"
                        dt << Recode Column (dt :"19-04-2024",
                        Target Column( :"19-04-2024" ) );
This part
dt[1::10, 4] = .;
was there to just add some missing values for demonstration purposes (first ten rows of column 4) so you can remove it.
Dennisbur
Hello
I tried to change  dt :"19-04-2024" to dt [1::10, 4], but it doesn't change the empty volume to 0
can you check where I was wrong?
                        dt << Recode Column (dt [1::10, 4],
                        Target Column( dt [1::10, 4] ) );
You should only need this part
	AsColumn(dt, 4),
where you define your column index inside AsColumn.
If I have table like this
and I wish replace missing values of column index 1 and 3, I would use
	As Column(dt, 1),
	Target Column(As Column(dt, 1))
and
	As Column(dt, 3),
	Target Column(As Column(dt, 3))
(number inside As Column has changed)
yes, the command line
dt[1::10, 3] = .;
set all values in the rows 1 to 10 in that third column to empty. The rest of the script replaced the empty values with 0. So as @jthi explained, just remove the line.
/****NeverStopLearning****/
Level XIII
There are 2-3 tricks how to fix such issues:
- Name Expr(As Column(...))
- Eval(Substitute(Expr(),... , ...)))
- if there is a 3rd one, it can be found here: Expression Handling in JMP: Tipps and Trapdoors
my col = Name Expr( As Column( dt, 2 ) );
Eval(
	Substitute(
			Expr(
					_col_,
					{Map Value( _rcOrig, {14, 0}, Unmatched( _rcNow ) )},
					Target Column( _col_ )
		Expr( _col_ ), Name Expr( my col )
Dennisbur
Hello
If I understood your suggestion well, it is to change:"19-04-2024"  to your script.
but I got the error. Can you check where I was wrong?
                      (my col = Name Expr( As Column( Column( dt, 3 ) ) );
                       Eval( Substitute( Expr( dt << Recode Column( _col_,
                       Target Column( _col_ ))),
                       Expr( _col_ ), Name Expr( my col ))) ),
Level XIII
The idea is:
get a module which can be used in a flexible way, the handle is my col :
my col = Name Expr( As Column( XXX) );
Eval(
	Substitute(
			Expr(
					_col_,
where  As Column(XXX) can be replaced by
  • As Column (column ("sex"))
  • As Column(dt, "sex")
  • As Column("sex")
  • As Column(3)
  • As Column(dt, 3)
  • in your case:
    As Column(dt, "19-04-2024")
    or  just As Column("19-04-2024")
edit:
as Jarmo shows in some post before:  https://community.jmp.com/t5/Discussions/Begin-Data-Update/m-p/752334/highlight/true#M93383 ,  for Recode Column, actually
- one doesn't even need the Eval(Substitute(...))
- nor the Name Expr(As Column(xxx))
... Recode Column(AsColumn(xxx)...) is enough.
wow!
