fishguy
Bar graph - label bars with sample size
I use JMP 17 (non-pro).
I would like to label bars in a char chart with data from another column, such as sample size, rather than the default options of value, percent or row. Can this be done?
I have included an example. The yellow highlighted labels in the chart are the 'values' for each bar. Instead, I would like to change them to 'N Rows' from the example data table, which is the sample sizes. My current approach is to pull the chart into Adobe Illustrator, which is a very kludgy solution.
Re: Bar graph - label bars with sample size
Set label property to the column
and then use Label by Row in graph builder
fishguy
Excellent Thanks!!
