scott1588
Customize Column Name for Save Predicteds Column
The following code launches the Bivariate platform and then saves predicted values in a column. This works fine. However, I would like to customize the column name for the save predicteds column. The Scripting Guide suggests sending nested messages but I can't seem to get that to work.
So the questions are...
1) Is it possible to customize the name of the Save Predicteds column within the platform options?
2) If not, how do I capture the name so I can customize it is subesquent steps?
Thanks much for any assistance anyone can provide.
Names Default to Here(1);
// SETUP
dt2 = New Table( "Interpolated Data",
	Add Rows( 60 ),
	New Column( "Timestamp",
		Numeric,
		"Continuous",
		Format( "m/d/y h:m", 19 ),
		Input Format( "m/d/y h:m" ),
		Set Values(
			[3742070400, 3742070460, 3742070520, 3742070580, 3742070640, 3742070700,
			3742070760, 3742070820, 3742070880, 3742070940, 3742071000, 3742071060,
			3742071120, 3742071180, 3742071240, 3742071300, 3742071360, 3742071420,
			3742071480, 3742071540, 3742071600, 3742071660, 3742071720, 3742071780,
			3742071840, 3742071900, 3742071960, 3742072020, 3742072080, 3742072140,
			3742072200, 3742072260, 3742072320, 3742072380, 3742072440, 3742072500,
			3742072560, 3742072620, 3742072680, 3742072740, 3742072800, 3742072860,
			3742072920, 3742072980, 3742073040, 3742073100, 3742073160, 3742073220,
			3742073280, 3742073340, 3742073400, 3742073460, 3742073520, 3742073580,
			3742073640, 3742073700, 3742073760, 3742073820, 3742073880, 3742073940]
		Set Display Width( 250 )
	New Column( "Data",
		Numeric,
		"Continuous",
		Format( "Best", 15 ),
		Set Values(
			[899.08410644531295, ., ., ., ., ., ., ., 897.38671875, ., ., ., ., ., .,
			., 898.518310546875, ., ., ., ., ., ., ., 897.57525634765602, ., ., ., .,
			., ., ., 897.38671875, ., ., ., ., ., ., ., 896.63226318359398, ., ., .,
			., ., ., ., 896.25506591796898, ., ., ., ., ., ., ., 896.44366455078102,
// RUN PLATFORM
// QUESTION 1: Is it possible to customize the name of the Save Predicteds column within the platform options?
// QUESTION 2: If not, how do I capture the name so I can customize it is subesquent steps?
dt2 << Bivariate( Y( :Data ) , X( :Timestamp ), Fit Spline( 1e-15, {Save Predicteds} ), Invisible );
Re: Customize Column Name for Save Predicteds Column
The simple method that I would use is:
predictedName = Column( dt2, N Cols( dt2 ) ) << get name;
scott1588
Jim,
I didn't think about that. The platform will always dump the predicteds at the end of the table so it will always be the last column.
Perfect and simple.
Thanks much.
A bit more generic option is to utilize associative arrays. For example if you fit models to multiple Y at the same time, you will end up with multiple columns
dt = Open("$SAMPLE_DATA/Diabetes.jmp");
original_columns = dt << Get Column Names("String");
obj = dt << Neural(
	Y(:Y, :BMI),
	X(:Age, :BP, :Total Cholesterol, :LDL, :HDL, :TCH, :LTG, :Glucose),
	Go
obj << Save Formulas;
obj << Close Window;
new_columns = Associative Array(dt << Get Column Names("String"));
new_columns << Remove(Associative Array(original_columns));
new_columns = new_columns << get keys; // Note that these are in alphabetical order
// If the order causes issues, it can be mitigated with some tricks
// This will rename also the hidden layers which could potentially cause issues For Each({colname}, new_columns, Column(dt, colname) << Set Name((dt << get name) || " " || colname); );
