Others should chime in since my answers may have ideas that I did not think of.
1) I am assuming you are trying to import Excel workbooks since you mentioned several tabs. You can certainly import an Excel workbook with multiple tabs into a single data table. You can import multiple Excel files at once, but they may not be into a single table. I do not think you can do both at the same time. But you could do it as a two-step process: bring in each file with the multiple tabs and then join the resulting JMP data tables.
2) You should read the post in the discussions that state that JMP is not a spreadsheet. You can calculate the average and standard deviation for multiple columns using the Table > Summary command. This will put the results into a new data table. If you MUST have the results in the same data table as the raw data, then you can use column formulas to calculate averages and standard deviations. There are other ways that can accomplish this task depending on exactly what you would like to do and why. Sometimes the best answer may not always be what you are thinking of doing.
3) If you fit a linear model, what "sigma" are you using for the bands? I would worry about misleading graphs. Using the standard deviation of the response would not be appropriate. Some of that variance has been explained by the X-variable. You could use the RMSE of the model fit, but is that really the proper error? Are you wanting to form a 99.7% confidence interval for the fit? 99.7% confidence interval for the prediction? Those are options that are available under the red triangle for the linear model that was fit to the data. Ultimately, it really depends on what you are trying to do with that interval.
4) Yes, this can be done. You will likely want to use a formula column to determine if a value is in spec or not. Having that information in a column will allow you to easily mark the data points as in/out of spec in Graph Builder.
I hope that others will chime in with more details. It may be better for you to have each question separated into a separate thread as they are quite different. More specific can then be asked and answered for each question. Best of luck on your JMP learning path!
Dan Obermiller
