d_barnett
Autorunning of JMP Scripts at a Specific Time
I have a set of scripts ( 7 in total) that I want to autorun at a specific time during the early morning so that the data is available to me when I get into work. All of these are saved as jsl files and I would like to queue these to run, these are stored on my hard-drive and JMP will be open and connected to a database..
Is there a way within JMP to do this? if I want to run these .jsl scripts to produce the data, some of these scripts extract large data sets from databases and can take ~30 mins to do so are very time consuming when I could be doing analysis ( and having my first coffee of the day).
As a build on to this t would also be good if I could use this for and JMP files ( .jmpquery in particular) to make it ultra useful.
Regards
David
msharp
Re: Autorunning of JMP Scripts at a Specific Time
What I usually do is create a .bat file then go to Task Scheduler to run the .bat file when I want it to.
Here's the basics of my .bat file.  Just copy and paste it into a txt file and save the extenions as .bat. Change (***JSL FILE LOCATION***) to your jsl script file location and copy the line for all 7 scripts.
:: Batch file that runs all JSL scripts
:: C:\logfile_source.txt is created to record results.
set logfile1=C:\temp\logfile_source.txt
"C:\Program Files\SAS\JMPPRO\12\Jmp.exe"  ***JSL FILE LOCATION***
echo.JMP scripts have completed %date% %time% >> %logfile1%
Task Scheduler can be found Windows>All Programs>Accessories>Sytem Tools>Task Schedule.  It's a pretty simple intuitive program.  If you can't figure it out you can quickly find a tutorial on YouTube.
msharp
ian_jmp
Level X
If the JMP session is already active, you should also take a look at Scheduling Actions.
