Auto import JMP plots, tables and test scripts into a Word file
How can JMP plots, tables and test scripts be imported automatically into a Word document?
Re: Auto import JMP plots, tables and test scripts into a Word file
Here is an example taken from the Scripting Index
//This message applies to all display box objects
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save MSWord( "path/to/example.doc" );
