OneNorthJMP
Auto Scaling of Variability Chart Y-axis based on USL & LSL spec limit
When there is outlier data, my chart is always being scaled to mix or max point, which make the chart not visible.
Is that possible to use JSL script to set the Variability Chart Y-axis dynamically based on the parameters USL & LSL limit that already embeded inside the parameters? Please advice. Thanks
Re: Auto Scaling of Variability Chart Y-axis based on USL & LSL spec limit
Here is an example script showing the precise code on using the USL and LSL to set the Max and Min axis settings.
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
// Turn on Show Limits
spec = dt:NPN1 << Get Property( "Spec Limits" );
	If( Is Empty( spec ) == 0,
		LSL = Try( spec["LSL"], . );
		USL = Try( spec["USL"], . );
		Target = Try( spec["Target"], . );
		Eval(
			Substitute(
					Expr(
						dt:NPN1 <<
						Set Property(
							"Spec Limits",
							{LSL( __LSL__ ), USL( __USL__ ),
							Target( __Target__ ), Show Limits( 1 )}
				Expr( __LSL__ ), LSL,
				Expr( __USL__ ), USL,
				Expr( __Target__ ), Target
// Build the Chart
vc = Variability Chart(
	Y( :NPN1 ),
	X( :lot_id ),
	Max Iter( 100 ),
	Conv Limit( 0.00000001 ),
	Number Integration Abscissas( 128 ),
	Number Function Evals( 65536 ),
	Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
	Std Dev Chart( 1 )
// Set the Min and Max
Report( vc )[axisbox( 1 )] << Max( spec["USL"] );
Report( vc )[axisbox( 1 )] << Min( spec["LSL"] );
15 REPLIES 15
The simple answer is yes......see
     Help==>Scripting Index==>Axis Box
Here is an example from the Scripting Index using Bivariate, but the same functionality is available for the Variability Chart
biv = Bivariate(
	Y( :weight ),
	X( :height ),
	FitLine
rbiv = biv << report;
axisbox = rbiv[axis box( 1 )];
axisbox << Max( 120 );
OneNorthJMP
Hi txnelson,
Thanks for advice. But unfortunately it is not the solution that i looking for. The axis box will prompt the user to key in the min / max manually. I want the JSL to take care of scaling automatically according to the params embededed LSL & USL spec without human interaction.
Is there any option to do so?
		Eval(
			Substitute(
					Expr(
						dt:NPN1 <<
						Set Property(
							"Spec Limits",
// Build the Chart
	Y( :NPN1 ),
	X( :lot_id ),
	Max Iter( 100 ),
	Std Dev Chart( 1 )
OneNorthJMP
Thanks Jim. It work perfectly!
AdamChoen
I want to use the same solution for my trend charts, but I'm having syntax issues.
someone know what fields I need to change if my limits column name are: "CENTERLINE", "LCL_HS", "UCL_HS"?
and also if I need adjustment if I'm creating a Bivariate chart BY columns?
thanks!
Thanks, Adam
Greenhorn
how to modify this script below to scale the graph automatically to LSL and USL.
@martindemel
Oneway(
	Y(
		:Name( "test1" ),
		:Name( "testn" )
	X( :Corner ),
	All Graphs( 0 ),
	Plot Quantile by Actual( 1 ),
	Line of Fit( 0 ),
	Std Dev Lines( 1 ),
	Legend( 0 ),
		Dispatch(
			{"Normal Quantile Plot"},
			"Oneway QuantilePlot",
			FrameBox,
			{Row Legend(
				Corner,
				Color( 1 ),
				Color Theme( "" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
Here is a script that should show you how to get the axes correctly specified.  The new learning you will need to study is the manipulation of Display Trees.  This is documented in the Scripting Guide found in the JMP Documentation Library
     Help==>JMP Documentation Library
colList = {"NPN1","PNP1"};
For(i=1,i<=N Items(colList),i++,
spec = column(dt,colList[i]) << Get Property( "Spec Limits" );
		Eval(
			Substitute(
					Expr(
						column(dt, colList[i]) <<
						Set Property(
							"Spec Limits",
// create the graphs
ow = Oneway(
	Y(
		:Name( "NPN1" ),
		:Name( "PNP1" )
	X( :site ),
	All Graphs( 0 ),
	Line of Fit( 0 ),
	Std Dev Lines( 1 ),
	Legend( 0 ),
		Dispatch(
			FrameBox,
			{Row Legend(
				Corner,
				Color( 1 ),
				Color Theme( "" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
owr = ow << report;
// adjust the axes
For( i=1, i<= n items(owr),i++,
	(owr[i])[AxisBox(2)] << min(spec["LSL"])<<max(spec["USL"])
Greenhorn
Thanks! It worked.
1)
Could you also please help me to adjust the x axis settings with the help of a script?
There is no values between LSL and USL.
Perhaps, there is a strategy to adjust the x axis with meaningful Tick/ Bin Increment automatically?
2)
Is it possible to give colList = {"NPN1","PNP1"}; to
ow = Oneway(
Y
:Name( "NPN1" ),
:Name( "PNP1" )
), --> instead of :Name(), :Name()
Please see the script below for the changes required to handle your new requests.  In most cases, any list of columns will be able to be substituted into a Platform request, with an Eval() function, which expresses the list to JMP.  See the
Eval( colList )
in the script below.
Assuming you have now read the section on Display Trees in the Scripting Guide, the messages that can be passed to the Display Objects are documented with examples in the Scripting Index
Examining the Messages for AxisBox(), you will see all of the messages available.  Among which is Inc().  It is this changing of the increment of the axis that is being used to insure values in the graph after changing the min and max axis values.
colList = {"NPN1", "PNP1"};
For( i = 1, i <= N Items( colList ), i++,
	spec = Column( dt, colList[i] ) << Get Property( "Spec Limits" );
		Eval(
			Substitute(
					Expr(
						Column( dt, colList[i] ) << Set Property(
							"Spec Limits",
							{LSL( __LSL__ ), USL( __USL__ ), Target( __Target__ ), Show Limits( 1 )}
ow = Oneway(
	Y(
		eval(colList)
	X( :site ),
	All Graphs( 0 ),
	Line of Fit( 0 ),
	Std Dev Lines( 1 ),
	Legend( 0 ),
		Dispatch(
			FrameBox,
			{Row Legend(
				Corner,
				Color( 1 ),
				Color Theme( "" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
owr = ow << report;
// adjust the axes
For( i = 1, i <= N Items( owr ), i++,
	(owr[i])[AxisBox( 2 )] << Min( spec["LSL"] ) << Max( spec["USL"] )
		<< inc ((spec["USL"] - spec["LSL"]) / 10 );
