Association Analysis not showing up in JMP Pro 16
I am using JMP Pro 16 in my MIS class and I cannot see the option for Association Analysis when I Select Analyze > Screening > Association analysis. Please Help
Re: Association Analysis not showing up in JMP Pro 16
Are you running JMP Pro?
If you truly are running JMP Pro, then you need to contact JMP Support
     support@jmp
Go to
     File=>Preferences=>Menu
Make sure Advanced Modeling is checked.
Thank you for your response. Advanced Modeling is checked in my Menu Preferences. I unchecked it, clicked apply, and then checked it and hit apply again. Still not seeing Association Analysis.
     support@jmp
I see it using JMP Pro 16.2:
You might try resetting the menu to original factory default:
mikedriscoll
Can you see other JMP Pro platforms? If not, maybe the pro features somehow got disabled. you could try running the code below in a script window.  I saw similar code on this forum a few weeks ago where someone wanted to disable the Pro features for training purposes, the response was to run the code below with a '1' in the 2nd line. I don't have JMP pro, so I can't test it, but it might need a JMP restart after running.
Names default to here(1);
preferences(disableJMPPro(0));
