Assign unique ID for each unique text
Hi all,
I would like to get your help in the following case. I have a data that dealing with drugs and their specific problems within different firms. The two columns (i.e. drug name and problem specifications) are text data. I would like to create a third column (continous one) that add unique ID to each drug name when it appears. For instance, Piperacillin Sodium and Tazobactam Sodium is drug name. When ever this name appear assign ID=1. If the drug name changed to Zoledronic Acid, for instance, ID=2 and so on so forth. Could you please help me in building formula in JMP to address this case? Best, Qais
Re: Assign unique ID for each unique text
Here is a script that runs against a sample data table that creates an ID column with a formula as you want
dt = Open( "$SAMPLE_DATA\cars.jmp" );
dt << New Column( "ID",
	formula(
		If( Row() == 1,
			Summarize( drugs = by( :Make ) )
		Contains( drugs, :Make );
There is an add-in in the Add-in Depot that basically does this. It's called "compress to labeled code." You want the revised version. Run the add-in on the column with the text. This will create a new column called "<column name> coded". Go into the column properties and turn off the value labels and click apply. You should be left with what you are after.
Best,
M
	formula(
		If( Row() == 1,
Thank you so much Sir for your amazing professional help. Problem solved. Any recommendation in improving my skills in writing such advance JSL formula?
Best,
Qais
My suggestion is to read the documentation provided by JMP.  Of the several books downloaded when you install JMP:
     Help==>Books
I suggest that you read,
     Using JMP
     Basic Analysis
     Essential Graphing
     Scripting Guide
This is a lot of reading, however, JMP is a powerful product with a lot of capabilities
Best,
M
Thank you so much. Well done
