- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Assessing for colinearity for categorical variables and/or binary outcome
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Assessing for colinearity for categorical variables and/or binary outcome
From the Fit Model dialog, have you tried switching to Generalized Regression? From there you can say the response has a binomial distribution. This should give you a fit that is very similar to the nominal logistic regression and it offers the ability to look at the Correlation of Estimates table. You can use that to understand the collinearity. Otherwise you can study the collinearity of the main effects by using Multivariate Methods > Multivariate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Welcome in the Community !
In addition to the solution proposed by @Dan_Obermiller, one possible "trick" to evaluate collinearity using VIF values is to create a random "dummy" numeric column, fit a multivariate regression model, and display VIF values of the model's variables. See How to examine VIF in a generalized regression report? and the response from @cwillden.
VIF are calculated only using values from input data/factors, (see equation here : Parameter Estimates for Original Predictors), so no matter the response type, you can always calculate and analyze VIF values.
Hope this workaround may help you,
