BookmarkSubscribeRSS Feed
claude_bellavan
Community Trekker
Nov 5, 2014
Any standardize function by subset
I have three columns:  Population, Year and Type. I need to write the Z score value of the population in a new column. This standardization applies for each subset (Year + Type). Until now, I've used the distribution platform with «BY Year» and «BY Type» and saved the normalized data (red triangle menu, Save standardized value).
Since I have to update my table often, these values have to be refreshed dynamically (formula column). The problem here is that the Standardize function applies to all rows. Is there any function or special arguments that would standardize «on the fly» my population by subset?
Thanks,
Claude B.
Jun 22, 2012
Solution
Re: Any standardize function by subset
Claude,
I believe the answer to your question is to just create a new column and to use the following formula for the new column:
(:Population-Col Mean(:Population,:Year,:Type)) / Col Std Dev(:Population,:Year,:Type)
JIm
Jun 22, 2012
Solution
Claude,
JIm
claude_bellavan
Community Trekker
Nov 5, 2014
thank you very much Jim!
CB
andy_rogish
Senior Member
Nov 3, 2014
Great and helpful response. It cut through the data and gave me what I needed, like a knife through hot butter!
