Hi @jmpneeeewbie,
If I understood correctly what you would like to do, one possible option for this would be to have two columns of equipment responses, one for each equipment, and then create a calculated column "EquipA - EquipB" (difference between the values of the equipment on which you'll do your equivalence test).
Then, you use this calculated column with the platform "Distribution", and on the red triangle you click on "Test Equivalence". You have to enter Target (here 0 since you don't expect a difference between the two equipments, or +/- a value if equipment B has constantly lower or higher values), a value for a difference you'll consider being practically zero, and the confidence level for this Two One-Sided Test (so if you want a 95% confidence interval in your output, specify a confidence level of 0,975). The default level 0,95 will give you an output with a 90% confidence interval.
See the datatable here in example with the script for equivalence testing.
I hope it will help you,
Victor GUILLER
